Ir2025i
  • copicatt
    • Nov 2008
    • 366
    Ir2025i
    I picked up 1 of these from a wholesaler today but under the send tab there is no option for email or file only fax. It is an i series so it must have been turned off? Any ideas?
    Re: Ir2025i
    Go into service mode and report then spec report and print the list it should look something like the following
    ACTIBAT FUNCTION_ _ _ _ _OFF
    BDL-IMAGE (1200)_ _ _ _ _ON
    FAX_ _ _ _ __ _ _ _ _ON
    NETWORK_ _ _ _ _ON
    PCL_ _ _ _ _ON
    PC-SCAN_ _ _ _ _ON
    BW-SEND_ _ _ _ _OFF
    CL-SEND_ _ _ _ _OFF
    PAF_ _ _ _ _OFF
    BDL-IMAGE (600)_ _ _ _ _OFF
    E-RDS_ _ _ _ _OFF
    • copicatt
      • Nov 2008
      • 366
      Re: Ir2025i
      Ok. Will check when I get back to the shop... So If it shows off.... How do I turn it on? Thanks!
      • copicatt
        • Nov 2008
        • 366
        Re: Ir2025i
        Heres what I get:
        NETWORK_ _ _ _ _ON
        PCL_ _ _ _ _OFF
        PC-SCAN_ _ _ _ _OFF
        BW-SEND_ _ _ _ _OFF
        CL-SEND_ _ _ _ _OFF
        PAF_ _ _ _ _OFF
        BDL-IMAGE (600)_ _ _ _ _ON
        E-RDS_ _ _ _ _OFF
        THIS IS AN "I"SERIES SO I DON'T UNDERSTAND WHY SCAN WOULD BE OFF.
        • copicatt
          • Nov 2008
          • 366
          Re: Ir2025i
          maybe possible that the license got deactivated or something? It has the send tab and looks normal but when you press "new address", it only has fax option.........
          • copicatt
            • Nov 2008
            • 366
            Re: Ir2025i
            Any one with any ideas whatsoever???
            Would like to install this tomorrow if possible!
            • Brian8506
              • 1665
              Re: Ir2025i
              I know very little about that machine but on the earlier ir's there was an option in sm to have tabs on or off. Maybe contact Paul at justmanuals. I would think the info would be in service manual. Teckat's on the beach drinking beer right now otherwise he probably would have chimed in.
              • copicatt
                • Nov 2008
                • 366
                Re: Ir2025i
                Thanks for the reply. I have the manuals but can't locate anywhere to bring the scan to email back. I will keep searching.
                • mjarbar
                  Re: Ir2025i
                  Hello,
                  I don't know if this will help but a similar thread was on here with the same problem but it was an iR1020 series machine.
                  http://www.copytechnet.com/forums/ca...ail-issue.html
                  Teckat gave a very good reply that may have possibilities for your problem.
                  • copicatt
                    • Nov 2008
                    • 366
                    Re: Ir2025i
                    Thanks for the info! That does seem like the same problem I am having. Just for giggles, i pulled the usb drive on a working machine and it gave the same symptom as this machine.... So i then swapped the drives but the problem remained.... In other words swapping the drive did nothing for me.
                    • mjarbar
                      Re: Ir2025i
                      From what I can see the drive is machine specific i.e. tied to the serial number, but I am glad that by pulling the drive you manged to recreate the prob as that means you are half way to getting it working again
                      • copicatt
                        • Nov 2008
                        • 366
                        Re: Ir2025i
                        I took out the drive and tried in another machine and it worked in that machine fine. So maybe it works with a certain version and I lucked out.
                        • copicatt
                          • Nov 2008
                          • 366
                          Re: Ir2025i
                          Figuring may just have to update the firmware. Guess I need to locate some system software for this and make sure my sat is compatible. This will be my first flash on this series.
                          • bipc
                            • Sep 2009
                            • 194
                            Re: Ir2025i
                            your best bet is to update it, in irXXXXi machines the send is always active as a predefinition, fax is optional but the send is always included, if you need help with the firmware PM me and i can get it for you, you'll need updated SST also and a "cross over" network cable to avoid connecting through a hub/switch, it's pretty much straithforward
                            Life is a learning continuum...
                            • copicatt
                              • Nov 2008
                              • 366
                              Re: Ir2025i
                              My sst is 4.3. Think the 2025i manual calls for 3.21 or later. So it should be fine. I have pm'd you!
