Service Support tool error
  • rferdi91
    • Jan 2011
    • 21
    [Error Code] Service Support tool error
    need help guys !!!!
  • Canon.Tech
    • Mar 2009
    • 335
    Re: Service Support tool error
    Need more info from you, like what model machine is it & what fault do you have etc
    • rferdi91
      • Jan 2011
      • 21
      i'm trying upload mode on ir105, but it always error 8
      • teckat
        • 16083
        ??????? Upload what from SST
        • Canuck
          Tech Specialist
          • 1713
          The pink screen of death
          • teckat
            • 16083
            • rferdi91
              • Jan 2011
              • 21
              if you wanna help just help me,, if you don't just leave me ALONE !!!!!
              • creatinchaos
                Agree, we need some more infor in order to help you. I cannot read from your picture but it looks like error4 is this correct? Have you tried switching to "low" speed more within the Support Tool? Are you placing the machine in proper "download" mode??? You are using an old version of Service Support Tool. Canon is up to v4.72Ek. Let us know more if you can and we will try to help you. Most Service Support Tool issues are easy to fix.
                • teckat
                  • 16083
                  point to note---your attitude stinks/
                  u think we are supposed to be mind readers here-
                  u post a lack of information on your issue-
                  I posted a simple ?
                  Upload What !!!
                  • bipc
                    • Sep 2009
                    • 194
                    I posted a simple ?
                    Upload What !!!
                    i think teckat was and is trying to help you so don't be offensive, if you don't provide enough information for us to reach a possible solution we must ask you to provide it, that error could be from dozens of different reasons so if you want our help please give us more info if not... it's your choice
                    Life is a learning continuum...
                    • canonbundy
                      • Jun 2012
                      • 607
                      need help guys !!!![/QUOTE
                      SST Error 221.
                      Cause
                      Incompatibility between the BootROM and Main Controller Firmware. The BootROM must be upgraded first.
                      Action
                      Upgrade the BootROM first using the Single method in safe mode then reboot the device afterwards. After a successful BootROM flash you can perform the firmware set for collective downloading [ALL].
                      If the above remedy fails to correct the cause, listed below are 2 alternative solutions for this issue:
                      1. Carry and use a copier BootROM v8.38 or higher to format and install the System Software to the new HDD. The original BootROM [C or N] now can be upgraded, after flashing the System Software. Be sure the BootROM is model specific.
                      2. Bring the original BootROM that is lower than v8.38 to a known working machine and flash it to v8.38 or higher. Install the BootROM back into the original machine, format and install the System software.
                      • Nery_Jesus
                        • May 2014
                        • 5
                        Re: Service Support tool error 109
                        I have this error. please help.
                        thank you.
                        • teckat
                          • 16083
                          Originally posted by Nery_Jesus
                          [ATTACH=CONFIG]25713[/ATTACH]
                          thank you.
                          what are u trying to do ???
                          error in top right on menu ??
                          Note: u have a very old ver of SST
                          • Nery_Jesus
                            • May 2014
                            • 5
                            Excuse the ignorance.
                            What version do you recommend and if you can send the appropriate version.
                            Thank you.
                            • teckat
                              • 16083
                              Thank you.
                              U did not answer ??
                              what are u trying to do with SST
