IRADVC9060 E197-0000 Solved
  • Herrmann
    • Jan 2006
    • 792
    [Error Code] IRADVC9060 E197-0000 Solved
    Here is a new "MC Guyver" from me
    I had a few Boxes in the field throwing me an intermittand E197-0000 (Serial Communication Error between DC Control and Fixing/Feeder Drive Board). Service Manual says as usual: Replace Boards (to make Canon rich) but not with me
    I haunted the Error down to an unreliable connection between the fixing/feeder assy and the main frame connector. I think nearly every experienced technician has a pretty little package in reach, containing some screws, jesus rings, springs and washers, so do I. I got some washers, placed them between the fixing/feeder assy and the connector, so it raised 3mm and make a reliable contact in future with the main frame connector. Problem solved
    Just a head up to you, if you are running into similar problems
    Greetings from Germany
    Herrmann
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
  • canonbundy
    • Jun 2012
    • 607
    Re: IRADVC9060 E197-0000 Solved
    [ATTACH=CONFIG]21556[/ATTACH]
    Herrmann
    Onya Mate, same goes for all Units with a Drawer - Good Post.
    • vigour
      • Aug 2010
      • 1038
      Good Fix
      It takes me back to NP 6050 where we had to modify the springs and bolts on that connector
      I had my first one yesterday (subcode 000). I got off easy by sticking my (tweaker) small flat screwdriver back there and found some paper.
      Too bad you didn't ask. They have modified some of the connectors
      It happens on adv 6000/8000 series too.
      for subcode 002 you have to replace the fuser connector. Shimming it never works for me
      So far I have been able to get by with replacing the fuser side only.
      But I have heard of some where you have to do the frame side also.
      • Canuck
        Tech Specialist
        • 1713
        IRC6800....same problem....connector modification
        • vigour
          • Aug 2010
          • 1038
          I know but I'm trying to forget that model
          • lilleputte
            • Jan 2013
            • 154
            good find thx
