Laser Uint IR5075 Repair
  • satitjangdee
    • Jun 2011
    • 49
    [Electrical] Laser Uint IR5075 Repair
    My Laser unit not work, it get code 0100-001.
    How to repair?
    which compatible model machine?
  • officeware
    Re: Laser Uint IR5075 Repair
    i think not the laser just main charge unit dirty try to clean or replacet
    or you can change setting in body-potential control change to 1
    • Simons
      • Jun 2008
      • 490
      Circuit Board Repair, Canon, Ricoh, Savin, Lanier Gestetner, Konica, Kyocera Mita - Nation-Wide Repair Service, Inc. (NWRS)
      • Canuck
        Tech Specialist
        • 1713
        Primary duct cover broken probably. That cover that you take off to remove the primary......the upper left screw support breaks off and then the pin on the back of the duct doesn't fully open the laser shutter
        • Brian8506
          • 1665
          Thats the first place I'd be looking.
          • satitjangdee
            • Jun 2011
            • 49
            I had verified that Laser Unit is fault by put it in another machine (same model : IR5075) and Error E0100-001 go with this Laser.
            How to verify which part is fault, BD board or Laser Driver board?
            Thank for all advise.
            • Brian8506
              • 1665
              Canon parts book doesn't break it down in parts. Go with Teckats advice and contact Nationwide in Kansas for assembly. Price isn't too bad
              • satitjangdee
                • Jun 2011
                • 49
                Thank You.
