Canon iR1020 - E019-0002 Error Code
  • livewire
    • Sep 2011
    • 608
    Hi everybody,
    My client has Canon iR1020, which gives me an error E019-0002
    (Waster toner full detection sensor is faulty).
    We have Service Manual.
    The first thing I did was to change the drum unit (with old unit).
    I tried to change SSSW-SW34 bit 0 and bit 1. Default settings are 00000000 for all bits.
    Next step (from internet):
    "If you have an error code E019 on the screen. Turn off the main power, wait 10 sec.
    and turn power back on.
    If you still have error code,
    press "additional functions" key
    press at the same time the "2" and "8" keys
    press "copier"
    press "function"
    press "clear"
    press "ERR"
    press "OK"
    press "Reset" key 2 times
    turn main power off for 10 sec.
    turn main power on."
    but without any result.
    I replaced the waste toner sensor, but the problem remains.
    Can I do something else before changing the DC Controller PCB?
    Regards.
  • bipc
    • Sep 2009
    • 194
    Re: Canon iR1020 - E019-0002 Error Code
    hi, that error has the following description:
    "The waste toner full state was detected continuously for five or more seconds while the main motor was turning"
    and possible solutions:
    - Check the connector of the waster toner full sensor.
    - Replace the waste toner full sensor.
    - Replace the DC controller PCB.
    but according to all you've done to it and since the waste toner on that series is kept inside the drum unit have you tried a different Drum Unit? is it OEM? is the toner OEM? how many copies does it have of use? the sensor could be reading right and the drum have exceeded it's life expectancy and simply be full of waste toner, it wont cost nothing to check it, cheaper then the DC controller
    Life is a learning continuum...
    • livewire
      • Sep 2011
      • 608
      Hello bipc,
      thanks for the reply.
      Drum and toner are genuine Canon. Waste toner assembly is cleaned.
      The machine is about 34,000 copies. Sensor definitely works because I switched it to that of READER ASSEMBLY (Scanner).
      I was hoping to have another procedure to clear the error.
      The only remaining DC Controller PCB.
      Regards.
      • Canuck
        Tech Specialist
        • 1713
        Don't press 2 and 8 simultaniously on this model. Additional functions,2,8,then additional functions again sequentially. Don't hold 2 and 8 down. This will get you in service mode
        • livewire
          • Sep 2011
          • 608
          Thanks Canuck,
          will try this on Monday.
          Regards.
          • livewire
            • Sep 2011
            • 608
            Hi everybody,
            "Don't press 2 and 8 simultaniously on this model. Additional functions,2,8,then additional functions again sequentially. Don't hold 2 and 8 down. This will get you in service mode."
            I tried the way you Canuck said, but the result is the same.
            Regads
            • DAG COPIERS & COMPUTERS
              • Oct 2010
              • 860
              Originally posted by livewire
              Hi everybody,
              Regads
              Crosscheck just once more, before you go in for the expensive DC controller; the wiring or connection between the waste toner sensor and the dc controller. It could be a loose contact issue.
              • livewire
                • Sep 2011
                • 608
                Hello everybody,
                wiring between the waste toner sensor and the DC Controller PCB have been checked and are connected.
                Do you have a part number on the DC Controller PCB 220V, for Europe (if relevant).
                I have a parts catalog for iR 2018/2022/2025/2030 series.
                I do not know if there is a difference in numbers between 20xx and 10xx series.
                Thank you.
                • Canuck
                  Tech Specialist
                  • 1713
                  Hi everybody,
                  Regads
                  You must be doing something wrong. Thats how you get into service mode. Make sure you are pressing additional functions and not just asterick. Its right in the manual. Add func,2,8,add func...nothing held down
                  • livewire
                    • Sep 2011
                    • 608
                    do the following:
                    1.additional button
                    2.2 button
                    3.8 button
                    4.additional button
                    #SSSW, + button
                    #MENU, + button
                    #NUMERIC, + button
                    #SPECIAL, + button
                    #NCU, + button
                    #FAX, + button
                    #SCAN, + button
                    #PRINT, + button
                    #NETWORK, + button
                    #CODEC, + button
                    #SYSTEM, + button
                    #ACC, + button
                    #COUNTER, + button
                    #LMS, + button
                    #REPORT, + button
                    #DOWNLOAD, + button
                    #CLEAR, OK button
                    under clear menu
                    TEL&USER DATA, + button
                    SERVICE DATA, + button
                    COUNTER, + button
                    SOFT CNT, + button
                    TYPE, + button
                    HIST, + button
                    CARD, + button
                    ERR, OK button
                    E355, + button (Not used)
                    E719, OK button (Use it to clear the management information at the time of card reader removal)
                    #CLEAR MENU, OK button
                    PWD, + button
                    Regards
                    • livewire
                      • Sep 2011
                      • 608
                      Hi Everybody,
                      after replace DC Controller PCB, problem is solved.
                      • ahmad
                        • Jun 2010
                        • 28
                        Hi everybody,
                        press "copier"
                        press "function"
                        press "clear"
                        press "ERR"
                        press "OK"
                        Regards.
                        change d.c,
