replacing color toners for Canon irc5800
  • Vincent2000
    • Aug 2025
    Please help! I am unable to replace colour toner cartridge for Canon irc5800. I have instructions how to replace the toner cartridges. They came with the new set of toners I bought but I have misplaced these and now unable to replace the toners especially the colour cartridges. I managed to replace the black one which wss fairly simple. I know how to enter service mode and carry out certain functions of the machine. But I can't figure it out how to replace colour toners. I have replaced the yellow cartridge because I could see it when I open the colour toner supply cover. Would someone kindly help. Thanks
  • songela
    • Mar 2008
    • 216
    Re: replacing color toners for Canon irc5800
    Why can't you search and download a User Manual?
    • canonbundy
      • Jun 2012
      • 607
      If the machine requires a particular Colour Toner it will then display a message 'Replace Toner' & the Revolver will rotate to the Colour which needs to be replaced
      • Vincent2000
        Thank you for your interest in the issue. I would like a copy of User Manual if someone has and kindly shares . I have tried many times and failed to locate User Manual for this model. Many sites indicate they have it but in fact what they have is the brochure in about 12 pages including Canon website. I have service manual but strangely nowhere it mentions procedure for toner replacement. It did give instructions how to fit the toners for the first time and refer to: "Check to see that the control panel displays the message " set the cartridge"". Yet it did not mention how to get that message displayed. These instructions are written in the context where the machine does not have toners in it yet. To replace them may involve different procedures. Any other ideas ? Cheers.
        • songela
          • Mar 2008
          • 216
          I will try it for you but I beg your patience due to my schedule. If you guess it is taking too long, you may reminder me through PM
          • Vincent2000
            Thanks for your tip. Maybe that is the way but I remember having read somewhere it recomends to change all at the same time. Currently it displays the message for all of the colours one after another that colour toner almost empty but not require replacement yet. If you are right then I would have problems if the sensor for colour toner level does not work well. In case where a toner is already empty but no message displayed and no chance to replace the toner or where a toner which has been in the machine so long and can not be replaced. Currently some coliur seems to be missing. Are there any way to rotate and change all of them in one go. Nowhere in the Service Manual mentions procedure for toner replacement other than fitting them for the first time. Thanks again.
            • teckat
              • 16083
              see pdf-----Replacing the Toner Cartridge.pdfNOTERemaining toner is low.> appears, approximately 10% of the toner is leftComplete instructions on how to replace the toner cartridge can be accessed by pressing [Previous] or [Next] on the touch panel display.
              • Canuck
                Tech Specialist
                • 1713
                Yuk.....5800. Pull out the process unit. Release the turret by actuating solenoid at rear by hand. This will allow you to rotate the turret. If it is asking for toner replacement on all colors and they are not empty,then the sensor(mounted stationary) is not working properly. There is a prism on toner cartridge that refracts the infra red light from the toner sensor transmitter to receiver of it. If receiver receives light,toner is empty. I have had to replace the wiring harnesses at the front of the process unit for this problem. Clean that toner sensor while you got it open.If its dirty,it will think it always has toner...not your problem. Changed many harnesses for potential control errors,dirty prints(no pre-exposure),toner cartridge issues. I used to carry one with me when i was servicing them. None left in the field here.
                • Vincent2000
                  Originally posted by teckat
                  see pdf-----[ATTACH]21614[/ATTACH]NOTERemaining toner is low.> appears, approximately 10% of the toner is leftComplete instructions on how to replace the toner cartridge can be accessed by pressing [Previous] or [Next] on the touch panel display.
                  Thank you. Problem is solved.
                  • teckat
                    • 16083
