Imagepress c1 e000020-0184, e000020-0284
  • fer_auriazul
    • Jul 2025
    [Error Code] Imagepress c1 e000020-0184, e000020-0284
    Hi there,
    im new on the forum, im having this problem after 6 or 7 copies, sometimes is o184 sometimes 0284, we already changed the drum unit, hope someone could help me to solve this problem
  • teckat
    • 16083
    Re: Imagepress c1 e000020-0184, e000020-0284
    Originally posted by fer_auriazul
    Hi there,
    Check/Clean & or replace ATR sensor
    Clean the ATR sensor window and the ATR sensor shutter with lint-free paper. Avoid using abrasive material or solvents that will leave a film on the sensor window as this can generate an erroneous reading from the sensor.
    1) Remove the ATR sensor from the main body.
    2) Press the plunger of the ATR sensor lever solenoid in this ---> direction
    3) Clean the ATR sensor window and the ATR sensor shutter with lint-free paper .
    +++++++++ check
    In the field, because the slide rod attached in the rear side of P kit assembly was/is damaged, patch sensing shutter won't/didn't open and close, and E020-0x84 occurred.
    - E020-0x84: The difference between the detected value of the base (drum surface) of the patch image read sensor and the reference value of the patch image read sensor is 30 or less. The second digit of the detail code mean as follows: 1=Y, 2=M, 3=C, 4=K, 5=L(only C1+).
    1. Turn the main power switch OFF/ON
    2. Check the SL8 movement, that opens and closes patch sensing shutter, in Service Mode. If SL is working, proceed to step 3. If it is not working proceed to step 4.
    - Service Mode > COPIER > Function > PART-CHK > SL > using numerical keypad, input "8", and press OK. Turn it 0.5 sec ON, 5 secs OFF, 0.5 sec ON and 5 secs OFF.
    3. Check whether the slide rod [A] equipped in the rear side of P kit assembly is damaged. If it is damaged, replace it with a new one.
    4. Refit the connector related to the following
    - SL8: J204L
    - Back drive PCB assembly : J3802/J3810
    - DC controller PCB assembly: J1198
    FC6-1043=SLIDE ROD
    • kalimero777
      • Aug 2015
      • 5
      I'm the first time now and I'm not sure if I'm in the right place to write questions.
      I have a canon image press c1 with ceramic toners and my problem is that showing a error000002-486, in the press greyscale were lost Grayscale now are brownish mess, if anyone can help me, thanks in advance
      • teckat
        • 16083
        - Data from the Patch Image Scan Sensor (PS3) (performed sheet-to-sheet)
        The patch image scan sensor measures toner image formed in the drum, and based on the data collected
        the amount of toner supply is adjusted so that the over all density will get close to the target density.
        - Data from the ATR Sensor (PS7) (detects every 8 document output of color print on A4 paper)
        The ATR sensor detects the patch image density and the developer (toner and carrier) in the developing
        assembly cylinder of each color. If the results fall outside of the target density range, toner supply target
        will be either increased or decreased.
        u mean
        E020-0486
        xx=01:Y, xx=02:M, xx=03: C, xx=04:K
        xx86 At patch detection, the difference between the detected value of the patch image read sensor and the reference
        value of the base (drum surface) of the patch image sensor is 30 or less.
        Turn off and then on the main power.
        Inspect/Replace patch image read sensor.
        Inspect/Replace patch-detecting shutter.--
        COPIER>FUNCTION>PART-CHK>SL
        Specify a solenoid to be checked. (Range: 1 to 15)
        Operation method:
        1) Select this item.
        2) Enter the code of a solenoid using numeric keys. (8. SL8: Patch detection shutter SL)
        3) Press the OK key.
        4) Press SL-ON and check the operation
        SL-ON
        1) Select this item and press the OK key. ON/OFF operation is repeated in the following
        pattern.
        ON for 0.5 seconds --> OFF for 5 seconds --> ON for 0.5 seconds --> OFF for 5 seconds --
        > OFF
        ALSO~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~
        Try watching the turret movement, see if sometimes it would stop at different positions, even for the same color.
        May need to Replace the Rotary Motor Unit / FM2-2641-000
        • kalimero777
          • Aug 2015
          • 5
          I'm going to try to solve carefully by following these instructions, thanks a lot Teckat
