Canon IR3200 E602-0007
  • Lazuli
    Printer Technician
    • Mar 2009
    • 21
    I have a Canon iR3200 with E602-0007 that seems to be related to the hard disk. I have run the HD check and HD clear and they both check out OK. Does anyone please know what else would cause this error?
    David
  • DAG COPIERS & COMPUTERS
    • Oct 2010
    • 860
    Re: Canon IR3200 E602-0007
    David
    Hard Disk error. After checking the cable and power connector, I would probably start up the machine in 'safe mode', format ALL using SST and reinstall the System(system, language,RUI) , and then power cycle the machine and see if it works.
    • teckat
      • 16083
      David
      before u do a Format & re-load of firmware> I would look at the memory > remove>clean>re-seat or replace
      had a quite a few 3200's with that 0007 code & it was bad memory> discovered it by trial and error (replacing and format of HDD would not clear the 602-0007 error
        • Oct 2010
        • 860
        Well, experience is the best teacher!
        • Canuck
          Tech Specialist
          • 1713
          Do the firmware,overwrite all,no formatting. The color profile is missing. Quick to do before tearing into it. Like Teckat said, clean the ram and sub-board contacts. Notorious on this whole family of machines for poor contacts.
