Greetings to all.
Problem with Booklet Finisher-D1 (iR ADV 8105).
Stapling on corners - OK, the brochure - OK. Double stapling - only one back staple is present. The front staple is not present.
Codes of errors and jams in history are not present. The device worked without problems till the moment of replacement of a stapler unit (there was error Е532). After replacement some times double stapling was normal. There was a problem...
The system has been updated: MN - v46.02, FIN_CON - v33.01. What could happen?
Any ideas are accepted with gratitude..
Victor V
Victor V
