Canon Ir 2525
  • jonak21
    • Aug 2013
    • 6
    Canon Ir 2525
    good I have a problem with the photocopier. first appeared to me to prepare toner. Clean the OPC drum and ensenderla me this error appeared. Follow label instructions inside the toner access cover to change toner. I mean I do not recognize the toner and tried with several tornes and I get the same error. that might be?
  • teckat
    • 16083
    Re: Canon Ir 2525
    "PREPARE" message means that toner is not needed right now / u wait until message says "REPLACE"
    if message does not go away> u could have a bad engine controller.
    The part numbers for the engine controllers are shown below:
    iR2530/2525/2520 = 550 Sheet Cassette 1 model FM4-2864-000
    iR2530/2525/2520 = 250 Sheet Cassette 1 model FM4-2865-000
    • Canuck
      Tech Specialist
      • 1713
      Re: Canon Ir 2525
      Does the bottle rotate when you stick in the new tube of toner?
      • canonbundy
        • Jun 2012
        • 607
        Re: Canon Ir 2525
        If display shows 'cannot recognise Toner' - could be stripped Worm & Drive Gears in Bottle Drive and/or Hopper Drive Gearboxes. Have seen it a couple of times where the Handle (to lock the Bottle in place) has been forced down (because the Bottle was NOT Locked in properly) so the Toner cover can be closed .......and consequently stripped the Gears....dumb..
