MF4412 ERROR
  • pulkit jain
    • Dec 2012
    • 73
    MF4412 ERROR
    IN MF4412 it shows error code e202-0002 how to solve it!
  • teckat
    • 16083
    Re: MF4412 ERROR
    E202 0002 = Contact Sensor HP error,
    Failure in return
    When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies.
    (1) Check the connection of Flat Cable between Main Controller Board (J5) and Contact Sensor.
    (2) Replace the Flat Cable between Main Controller Board (J5) and Contact Sensor.
    (3) Replace the Contact Sensor.
    (4) Replace the Main Controller Board.
