IR C3380 Toner Hopper Problems
  • mrfixit
    Senior Technician
    • Sep 2007
    • 83
    Does anyone know why the toner cartridges won't turn properly when installing. I primarily see this on the black, when the toner cartridge latch is turned the gears will stick and skip. Seems like it may be a problem with the plastic toner frame. Does anyone have a good fix for this besides swapping the entire unit?
    Ray
  • Dan Dryer
    • Jan 2008
    • 57
    Re: IR C3380 Toner Hopper Problems
    The gears are attached to a flimsy metal frame. I usually reposition the frame slightly, so the gears mesh properly.
    • onlyinnewfoundland
      • Apr 2013
      • 235
      There was a mod to the gear assemblies...mainly because of the terrible design, the toner used to leak down onto the sensors directly beneath it. If the customer isn't careful installing they make a mess and you start getting e025 codes. I've had a few bottles where the gear simply would not mesh properly until I cranked it a few times, at which point I was sure I had broken it but it worked.
      Worst case, replace the bottle.
      • Canon.Tech
        • Mar 2009
        • 335
        Are you using genuine Caon toner? the non OEM toners have cheap flimsy gears.
        • canonbundy
          • Jun 2012
          • 607
          Ray
          This problem had me stumped for a while also, but if you take the Toner cover off there is a metal plate under the Black unit which has a hole .....and there should be a self tapper screw into the plastic frame - had 4 machines over the last couple of years with the same problem and I still don't know if there was supposed to be a screw there in the first place but it stops the frame from twisting and the gears mesh ok.
