Canon IRc3380 E000602-0003 code
  • wilez
    • Jan 2011
    • 55
    Need some help or advice. I am a Ricoh/Minolta tech with a Canon IRc3380 I support. In a nutshell this copier was donated to a non profit I assist, and last week after replacing the K drum unit this code appeared I performed the HDD rewrite procedure and cleared code.
    Now a week later code has returned, my thought is to replace hdd but it seems that the SST and Firmware is not easy to obtain. Now I will not act as if I have not seen all of the request on here for the SST and/or firmware and I am only putting my hat into the ring.
    Side note: I do not charge them for my labor, they do pay for parts but the work they are doing in the community is worth my support. So if there are some reasonable and reliable sources to obtain this let me know.
    P.M me or leave feedback here.
    Thanks in advance
    https://t.me/pump_upp
  • vamoursly
    • Sep 2011
    • 273
    Re: Canon IRc3380 E000602-0003 code
    From the SM, if you need anything else let me know.
    Vamoursly
    • wilez
      • Jan 2011
      • 55
      Did the HDD rewrite utility from tech mode again and advised customer to do shut down from control panel. It has been a week no call back.
      All is good in the world again, well maybe not all, but it is for them.
      Thanks Vamoursly for your help!!
      • vamoursly
        • Sep 2011
        • 273
        Glad to be of service
        V
