Have a I R 8070 that has says limited function mode on control panel, and says stapler can't be used. Seen this on other machines but not a 8070. Anyone now how to clear or reset limited function? Thanks
IR 8070
Re: IR 8070
most likely you are going to have to fix the stapler.
Press * button (additional functions)
-- press Common
scroll to about page 5 , you will see Limited functions, turn it off
Power cycle.
If your stapler problem is still there, you will see an E code. -
Re: IR 8070
This is where I have turned it off on other machines, problem is, it is not showing up there.Comment
