IR 1600 pickup problem in bypass
  • Guna
    • 27
    [Jamming] IR 1600 pickup problem in bypass
    In IR 1600 when the paper feed from bypass try the paper just pick up and stop near to drum and the paper jam.I check the manual clause bypass pickup sensor but the problem not solve.Can any body fix the problem ?
  • teckat
    • 16083
    Re: IR 1600 pickup problem in bypass
    jam code ----------- error code
    all paper sizes
    jam from bypass only ?
    is this issue from PC Printing or glass copying ?? or both
    • Guna
      • 27
      Nothing any error code only paper jam indicate.
      All size paper jam only when paper feed from bypass .And it is happen both from glass scaning and also computer prints.
      Pickup from all trays is ok.
      Regards
      Guna
      • teckat
        • 16083
        Regards
        Guna
        did u check the #10 REPORT= Jam/Error Log Report
        Indication : JAM/ERR LOG REPORT
        Type : jam, error, alarm history
        or Alarm History
        040017=multifeeder retry alarm
        How many jam indicators are lit on control panel
