on hook button greyed out receive errors
+ More Options
Posts
  • Simons
    • Jun 2008
    • 490
    symptoms are like line noise. can send and get faxs with problems. Not onsite yet . Never seen that before, greyed oout on hook button...
  • teckat
    • 16083
    Re: on hook button greyed out receive errors
    What model ??????????????????
    IRADV
    Most Options in the Fax Menu are Grayed Out The "Hook" Button is Grayed Out while viewing the Fax Menu on devices equipped with an Optional Fax Kit.
    Problem :
    The "Hook" Button is Grayed Out while viewing the Fax Menu on devices equipped with an Optional Fax Kit. The "Hook" button is not available while looking at the fax screen as shown here.
    Solution :
    This will be simply addressed by checking the current configuration as it relates to Fax. It will be necessary to "Turn Off" the option for "Limit New Destination" for fax as shown here.
    Enter the Limit New Destination Menu by executing the following keystrokes.
    Settings / Registration > (Logon as Administrator) > Function Settings > Send > Common Settings > Limit New Destination.
    Notice that in the condition where the Hook button is not available the option will be turned on as illustrated here
    To enable the Hook button, "Turn Off" the Limit New Destination for Fax as illustrated here.
    Once this is accomplished, the once grayed Hook button will now be available.
    • teckat
      • 16083
      What model
      While trying to use the On-Hook key for a fax transmission, it is observed that the key is not active or "Grayed Out", as shown below.
      Solution :
      The On-Hook Key is not active since the option to "Limit New Destinations" for fax has been set.
      To correct this, use the following key sequence to reach the menu shown below.
      Settings / Registration > Function Settings > Send > Common Settings > Limit New Destination.
      Once this has been corrected, the Hook Key will be active as shown below
      • Simons
        • Jun 2008
        • 490
        oops C2550 Color imageRunner.
        • teckat
          • 16083
          u have the Super G3 FAX installed
          • Simons
            • Jun 2008
            • 490
            Yes the W1
            • teckat
              • 16083
              Yes the W1
              any restrictions set up on printer or dept i.d.
              firmware ver. ?
              did u do a recent printer update lately ?
              • Simons
                • Jun 2008
                • 490
                No
                • Canuck
                  Tech Specialist
                  • 1713
                  What do you mean by line noise? To me that means a handset plugged into the handset jack on copier and hearing crackling...phone cord,etc. What errors are they getting...#018s? On all my fax connected machines, I set the attentuation to 8,NLE(noise line equalizer) to a 1. This enables it. If I remember off the top of my head,FAX/MENU/bit5 to a 1,bit7 to a 8. This gets rid of a lot of pesky communication errors. Make sure machine has latest firmware. Canon had some firmware out a few years ago on some models that the fax firmware had wrong country codes and other issues. I remember having to tweak fax service mode settings to correct them until Canon put out corrected software. Hope this helps
                  • Simons
                    • Jun 2008
                    • 490
                    All true and I do that on a regular basis to other machines. turning up attenuation is important. I am going on site next week. I have just never seen that button greyed if a phone line is plugged in and can actually fax!
                    • Canuck
                      Tech Specialist
                      • 1713
                      Just load firmware onto a flash drive and away you go...good luck and let us know how it goes
                      • Simons
                        • Jun 2008
                        • 490
                        Yeah a simple reload is no problem. I just updated the system a couple months ago. Now I fear a hdd failure soon.
                        • teckat
                          • 16083
                          ______;
                          Did u do the Fax procedure noted on teck pub after update ??
                          Many updates requirer a Fax clear & some noted checks\adjustments on G3
