Does anybody know if they're compatible to connect through usb?
IR1370 and Windows7
Re: IR1370 and Windows7
If you find one let me know. It's not an actual canon driver it's a capta driver or some garbage like that. So far have been unsuccessful in getting them running on windows 7Comment
Canon USA has them for windows vista X86 and you can use them on 7 X86 just don't use the installer go to printers and add a printer then give it the folder with the driver, for the X64 i will try to find one usable since here i only got the 1210 1230 and 1270FLife is a learning continuum...Comment
Most of our clients are now on x64 due to the memory limitations of x32. We've been using the opportunity to upgrade machines so it's a win winComment
