Canon Imagepress c6000vp E000260-1000-05
  • lilleputte
    • Jan 2013
    • 154
    [Error Code] Canon Imagepress c6000vp E000260-1000-05
    Hi!
    We have a ipc6000vp. The machine gives the error E000260-1000-05. Does anyone know what this is?
    /lilleputte
  • Joseph2011
    • Aug 2011
    • 88
    Re: Canon Imagepress c6000vp E000260-1000-05
    Originally posted by lilleputte
    Hi!
    /lilleputte
    Detail in E260-10xx/20xx (Power error)
    xx E260-10xx (24V/12V)
    Error: 24V, 12V power supply
    Unit-type 24V/12V error other than
    24V power supply errors (Detailed
    Codes: 0001 to 0004) mentioned above
    When detecting the error signal for
    500msec (100msec x 5 times)
    consecutively when the power was
    turned on
    • teckat
      • 16083
      Hi!
      /lilleputte
      E260 0002-05 when power up or E260 1000-05 if powered up with the Main Station doors open first.
      Solution :
      Followed the E260 Troubleshooting TP12-125a (attached) and the LED indications.
      TP12 125a-2.pdf
      • lilleputte
        • Jan 2013
        • 154
        This board layout are not the same on the ipc6000. We can not find the power unit limiter
        • lilleputte
          • Jan 2013
          • 154
          We fixed the error code. We replace the psu in the external unit
          Thanks /lilleputte
          • teckat
            • 16083
            We fix the error code. We replace the psu in the external unit
            Thanks /lilleputte
            -----Sorry missed the VP/ good find
