Scanning software for iR3025
  • Bidza
    I have just connected my ir3025 on to my network and it is working fine. I have also loaded scangear and when I run it, it actually sees the machine. But now when I want to scan, I cant see the programme to do the actual scanning. It doesnt seem to be included in the scan gear programme. Pliz help
    Thanx in advance
  • kuby
    • Oct 2007
    • 1400
    Re: Scanning software for iR3025
    It scans using Acrobat Standard or Professional and MS Word (some versions you have to make a macro to scan).
    • charm5496
      • 2387
      you have to turn the scanner "online" in order to use the network scangear program
      • doktor
        • 214
        Program ; Irfanview
        • teckat
          • 16083
          1-Before using the scanner driver for the first time, you need to select the network scanner to be used
          with the ScanGear Tool.
          2-ScanGear Tool cannot be started at the same time as the Network ScanGear/Network ScanGear driver.
          The window displayed may vary according to the operating system etc.
          as posted by charm5496
          To start the Network ScanGear driver and scan, first you must switch the scanner online.
          I hope u don't ask How do I turn Printer Online
          --You can also set the scanner to go offline automatically.
          --You do not have to switch the scanner offline in order to use other functions while data is being
          transferred.
          Network ScanGear driver is started by accessing it from a TWAIN-compliant application (such as Adobe Photoshop, Adobe Acrobat, Word/Excel/PowerPoint--etc.
          Network ScanGear Guide.pdf
