Canon IR-105+ making black copies .
  • impaqsol
    • Jun 2009
    • 87
    Hi,
    I have a Canon IR-105+ that is giving me black copies. Attached photo. I have exchange the following with another Canon same model with NO GOOD RESULTS, (Developer Unit, Charge Corona, Complete Drum Unit, HV Board), I have also check exposure lamp. Nothing is working.
    Does anyone have a suggestion.
    Rad
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: Canon IR-105+ making black copies .
    Originally posted by impaqsol
    Hi,
    Rad
    Hello,
    For a reason, the drum is not being charged to the appropriate value. I would execute a DCCON clear and put back the door values.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Hi,
      Rad
      [ATTACH=CONFIG]21938[/ATTACH]
      Is this off the glass?
      If so, do a CCD Adjust and see what happens.
      • canonbundy
        • Jun 2012
        • 607
        Hi,
        Rad
        Looks like a Bias/HV issue - replace T/Sep Corona Unit & HV Block check for Dev shorts - clean Fixing Drawer contacts incl connectors at rear of machine.
        • Canuck
          Tech Specialist
          • 1713
          What are VL and VD in service mode? Should be around 70 and 380..turn off potential control...any difference? Service mode..check if pre-exposure lamp comes on. You have changed whole process unit so that eliminates pre-exposure lamp and potential control sensor and front wiring harness. But step 1 is VL and VD...this will tell if drum is being charged properly(primary,VD) and if laser is discharging properly(VL) during potential control. DCON clear a good idea
          • COPIERTEC ASSOCIATES
            • Aug 2011
            • 279
            Originally posted by Rachid.Akli
            Hello,
            Rachid.
            Did you try a P-Print from the service mode? If the print is the same,try to perform the following;
            COPIER>OPTION>BODY>PO-CNT.If the value of PO-CNT is 1,change to 0 and viceversa and make
            a test print.
            • SAZ911
              • Mar 2013
              • 193
              Hi,
              Rad
              HI,
              have you checked your potential control, had similar issue with IR 7105....???
              SAZ911..........
              • Canuck
                Tech Specialist
                • 1713
                I ask again.....what are VL and VD???????????????????????? Lets troubleshoot and not just throw parts at it
