canon ir5055 droppig toner on the transfer/ sep corona unit
  • walterman
    • 196
    What cause this mfp to drop toner on the trans/ step corona unit? Is is a bad transfer/ step corona unit Loris it a seal I
    a seal in the process unit? Or something else causing this issue?
  • northernlife
    • Sep 2011
    • 847
    Re: canon ir5055 droppig toner on the transfer/ sep corona unit
    Usually bad cleaning blade on drum or a leaky dev
    • Canuck
      Tech Specialist
      • 1713
      Check the cleaner assembly. Broken auger,gear,waste drives. Turn the drive gear on the rear of the process unit and see if all augers in cleaner turn. There are also catch pans on the bottom of the process unit...they gather toner in them and drop it. I have had the waste tubes clog up on these(just like 5000s...keep the filters clean). Are the copies ok though?
      • canonbundy
        • Jun 2012
        • 607
        Remove the Process Unit, the Drum & vacout the Cleaner Unit etc including the Pre T/fer Unit, Flip or replace the Cleaning Blade, check in Srv Mode the life of the Primary & T/fer Units - replace if done life, should be good for 500k .
        • walterman
          • 196
          First off, let me apologize for my debauchery of the English language in my prior post, I was on my hand- held and did not realize my hack job grammatically. The copies look good, there are no streaks, I am under the impression, the cleaning blade was replaced recently. Canuck, I will check the above mentioned items. It is basically just a pile of toner that, over time, will disperse itself across the entire transfer/ separation corona unit evenly.
          • Canon.Tech
            • Mar 2009
            • 335
            Sounds like the pre transfer is full, one screw & this slides out, take the top cover off it & vacum it out.
