Resurrecting an old machine
  • adi_wazzup
    • Jul 2025
    [Misc] Resurrecting an old machine
    I am trying to get an old Canon Ir 6000i to work. The copier wasn't used for a long time ( a few years) and was abandoned in a garage. Pieces of it are missing and it is in a really bad condition. I have cleaned it and it seems that it's mechanics are fine. The problem is I can't find a code for the reader unit cable and I can't do anything until I find one because of the E00732-0001 error. Does enyone know if i can use the copier without the reader unit as a simple printer until I can find a cable? And if so how can I disable the reader? Also I would appreciate it if somebody could tell me how can I find a reader unit cable.
  • Canon.Tech
    • Mar 2009
    • 335
    Re: Resurrecting an old machine
    No not on this model you can't disable the scanner. On newer canon's you can. You will need to find that missing cable or order a new one.
    • canonbundy
      • Jun 2012
      • 607
      E732 codes are common on Canon Units that have been 'stored' for some time - without going to any real expense, remove and clean ALL the PCB contacts including RAM in the Controller Box - I use a cloth dampened with RP7 to clean contacts then buff with a dry one - 100% sucess for me .
      • Canon.Tech
        • Mar 2009
        • 335
        He's lost the reader unit cable, all the cleaning won't fix the error without the cable!
        • bipc
          • Sep 2009
          • 194
          well he just need's to find and assemble the cable and the good cleanup wont hurt
          Life is a learning continuum...
