ERROR CODE 004 CANON iR 5075
  • vr 43
    • Aug 2013
    • 2
    [Error Code] ERROR CODE 004 CANON iR 5075
    Dear My freind,
    I have copier machine canon iR 5075,the problem error code 004.Please help me to solve my problem.Thanks
    Beast Regads
    VR 43
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Re: ERROR CODE 004 CANON iR 5075
    Originally posted by vr 43
    Dear My freind,
    Beast Regads
    VR 43
    Reset the error code by clearing it out from service mode. Also check your fuser. This is a power related issue.
    • teckat
      • 16083
      Dear My freind,
      Beast Regads
      VR 43
      are u a tech ?????????? if not > call for one before u mess things up/ info below is for a tech who does not have a manual
      E004-xxxx ??
      The IH power supply is faulty/the IH control mechanism is faulty.
      After correcting the fault, be sure to reset the error. (COPIER>FUNCTION>CLEAR>ERR)
      what is sub-code
      0010 =The power has been turned off and then back on without resetting the error.
      - Reset the error.
      0101 =There is a mismatch between the input voltage and the IH power supply ID.
      Replace the fixing heater power supply with one designed for the country of installation (voltage).
      0102 =The IH current is faulty. (current leakage)
      0103 =The IH current is faulty. (no current)
      0104 =There is an IH over-current.
      0105 =The IH input voltage is too high.
      0106 =The IH input voltage is too low.
      0201 =At power-on (or, when IH is at reset), the IH control mechanism is not in an initial state.
      - Check the connector for any fault in connection.
      - Replace the fixing heater power supply.
      - Replace the DC controller PCB
      0202 =At IH start-up, the IH control enable flag is not set within 1 sec after the start flag is set.
      0203 =With IH at rest, the IH control flag is not released.
      0204 =The 12-V power supply (IH relay) is identified as being off.
      0205 =At IH start-up, the PWM/ON data is faulty ('0' or 'FFFF')
      - Replace the DC controller PCB.
      • vr 43
        • Aug 2013
        • 2
        E004-xxxx ??
        what is sub-code
        - Reset the error.
        THANKS SO MUCH MY FREIND,
        ERROE CODE 004 sub-code 0102,I try change the IH Board new one(I borrow the IH Board from my freind) than I follow your intruction to reset the error (COPIER>FUNCTION>CLEAR>ERR),My machine now working.Thanks so much for your support.I need wiring diagram for IH Board because I will try repair this board.
        Best Reagds
        VR 43
