Canon IR C2880i with J1 Fiery ... no SEND function?
  • RayCR
    • Oct 2012
    • 18
    Hi all, a few questions,
    There is no selectable send function on the device and I was wondering if it is because the J1 Fiery is installed?
    If so, will removing the fiery enable the send feature or is there some way to enable it with the fiery installed?...
    I was under the assumption that all the IR C2880i models came with the universal send (scan to email etc) feature as standard?
  • northernlife
    • Sep 2011
    • 847
    Re: Canon IR C2880i with J1 Fiery ... no SEND function?
    level 2 service mode > copier > option > body > 3/13 > UI-SEND is probably set to 0. want it set to 1
    • RayCR
      • Oct 2012
      • 18
      Indeed it is... do I set that to 0?
      • northernlife
        • Sep 2011
        • 847
        no 1 enables, 0 disables it from showing up on the main screen
        • RayCR
          • Oct 2012
          • 18
          Yes that makes sense, let me double check, I could have sworn it was set to 1... I take it it will need a restart...?
          • northernlife
            • Sep 2011
            • 847
            it's like windows 95, no matter what you do, reboot just to make sure you don't have any issues with it coming up.
            • RayCR
              • Oct 2012
              • 18
              • northernlife
                • Sep 2011
                • 847
                and still no send button? Do you have any other tabs than just copy? Express copy? Meap? any of those?
                • northernlife
                  • Sep 2011
                  • 847
                  lvl 1 > display > acc-sts > is send a 1 or a 0
                  They may have pulled the kit with a license transfer on that unit if it's at 0
                  • RayCR
                    • Oct 2012
                    • 18
                    But the send function is still not available (I did not have to change that setting it was indeed set to 1 nevertheless I restarted the machine incase it wasn't) any ideas?
                    • RayCR
                      • Oct 2012
                      • 18
                      send is 0 there...
                      • northernlife
                        • Sep 2011
                        • 847
                        Looking at my machine holdon a couple mins please
                        • northernlife
                          • Sep 2011
                          • 847
                          ah ok so acc-sts at 0 means the send kit has been pulled.
                          • RayCR
                            • Oct 2012
                            • 18
                            Ah ok, thanks so a new license OR license transfer will re-enable the send function?
                            • northernlife
                              • Sep 2011
                              • 847
                              You are 100% correct. When we chuck out a 3380 series we always lcns-tr those licenses.
