IRC 2550 z folding and jam code 0106
  • Bopper
    • 11
    Having a problem with Z folding at the registration roller and jam code 0106. Replaced registration clutch and pre-registration clutch. Machine seems to work fine through manual bypass. Swapped ports 1 and 2 with no change.
    • 16083
    Re: IRC 2550 z folding and jam code 0106
    check Lower right cover-------------
    registration roller is driven with the registration multi motor (M6)/ have seen this motor cause issues because it runs a normal speed & half speed
    this motor is also used for multi-feeder --When the registration clutch turns ON, the registration roller starts to rotate and feeds paper to the secondary
    transfer assembly.
    Unplug all connectors on DCPCB>then re-seat them
    check the sensor actuator arm below
    • Bopper
      • 11
      I tried all previous ideas with no luck. I did finally fix it by removing the registration sensor silencer, it was sticky resulting in a delay. Thanks for the help!
