better call a trained tech first !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
To enter Service Mode , follow the steps below:
1. Press the Additional Functions button.
2. Hit the 2 key.
3. Hit the 8 key.
4. Press the Additional Functions button.
* All keys are punched one by one without holding any other keys. The 2 and 8 keys are pressed separately, not simultaneously.
Error Code Detail Code Error Name/Explanation of Error
E000-0000 Fixing temperature abnormal rise
E001-0000 Fixing unit temperature rise detection (by main thermistor)
0001-Fixing unit temperature rise detection (by sub thermistor)
E002-0000 Fixing unit temperature insufficient rise
E003-0000 Low fixing temperature detection after standby (by main thermistor)
0001-Low fixing temperature detection after standby (by sub thermistor)
E007-0000 Fixing film rotation error
E010-0000 Main motor rotation error
E019-0001 Waste toner full detection
0002-Waster toner full detection sensor failure
E052-0000 Duplex unit connection error
E100-0000 BD cycle out of range
E196-0001 Error on writing and readout ROM of image processor PCB (main ROM).
0002-Error on writing and readout ROM of image processor PCB (option ROM).
E197-0000 Erroneous communication with printer engine
E261-0000 Zero-cross signal error
E500-0001 Finisher communication error
E520-0000 Offset error
E531-0000 Stapling error
E540-0001 Paper surface not detected (standard tray)
0002-Not moved within the specified time (standard tray)
0003-Sensor not reached within 3 seconds (standard tray)
0005-Encoder clock failure (standard tray)
E542-0001 Paper surface not detected (optional tray)
0002-Not moved within the specified time (optional tray)
0003-Sensor not reached within 3 seconds (optional tray)
0005-Encoder clock failure (optional tray)
E716-0000 Erroneous communication with optional cassette
E719-0000 Erroneous communication with card reader (serial communication)
0002-Erroneous communication with coin vender (serial communication)
E730-0000 Inside error of the image processor PCB (PDL system error)
E733-0000 Erroneous communication between controller and printer
E736-0000 CCU communication error
E739-0000 Erroneous communication between controller and network board
E744-0001 Language file/boot ROM/USB memory error
0002/0003/0004
E805-0000 Fan failure
E808-0000 Fixing drive circuit failure
