canon ir 105
  • Saji
    • May 2010
    • 97
    canon ir 105
    Canon ir 105, copies are with background in zoom, normal copies are ok. i did ccd adjustment etc.but problem still there, what could be the problem pls help.thanks in advance.
  • teckat
    • 16083
    Re: canon ir 105
    What % is the zoom / & what type of document (original-copy
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Re: canon ir 105
      Clean your optics for starters.
      Perform CCD with the brightest paper you have.
      • Saji
        • May 2010
        • 97
        Re: canon ir 105
        It comes any percentage of zoom,mostly customer makes zoom to make copies of id cards.we already adjust ccd with white paper on glass.
        • teckat
          • 16083
          Re: canon ir 105
          on the primary HVT there is a small switch, try to flip it and background gone ??
          Did u try to Decrease the value in the following ?
          in service mode:
          COPIER>ADJUST>AE>AE-TBL
          u could do a normal scan of the card/cards into a PC then > print from PC to 105 at a zoomed %
          id there a security Hologram on the id card
          place a OHP transparency sheet on the glass> then place the ID card on top of it> now run a zoom copy
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Re: canon ir 105
            How about this.
            When photo copying ID's use PHOTO instead of TEXT when making copies.
            The DPI resolution is less when you use PHOTO.
            • Saji
              • May 2010
              • 97
              Re: canon ir 105
              I followed sir teckats advice copy is some what better but still there is back ground while making zoom copies of id cards.
              i already tried the photo mode, but still it gives background.
              thanks
              • teckat
                • 16083
                Re: canon ir 105
                thanks
                what happens when u enlarge normal text documents to same ratio used on id cards ????
                do these OD Cards have a Matt Finish or a Smooth Finish
                what is ZOOM RATIO U USE ?????
                is it a solid background or when enlarged do u see fine lines
                -keep AE off
                -set PRE-TR to 165 and reboot
                -try replacing the Lamp
                -Check the Drum to make sure the drum heater is on and is warm. With a piece of paper in the palm of your hand, reach up and feel the drum with the paper acting as a heat shield. If ON the drum should feel warm.
                If not try setting SW3 at rear-lower-right to full-wave ( right dot pushed in). Re-check drum warmth again in a few minutes.
                Check the wiring harness in the front of the AP kit for continuity. A poor connection through the harness may cause the Pre-Exposure lamps to turn on intermittently.
                Clean the scanning lamp, reflecting plate, side reflecting plate, mirrors,
                lenses, and dust-proofing glass-
                THEN----
                Execute the following in service mode:
                1. COPIER>FUNCTION>CCD>CCD-ADJ
                2 COPIER>FUNCTION>CCD>LUT-ADJ
                Try to Increase the value in the following
                service mode: COPIER>ADJUST>CCDSH-TRGT (max. at 160)
