Canon copier IRC2880
  • willy brown
    • Aug 2025
    Hi all
    I set up this canon copier IR C2880, on the net work i can ping it, loaded the driver on the pc but I can not print. when I go to the printer log I can see what i have sent. what must I do to make the machine print.
    Will Brown
  • Copier_Guy
    • 543
    Originally posted by willy brown
    Hi all
    Will Brown
    You have to make sure the machine is a printer and not just a copier. You have to go into Service Mode and check the Boot ROM version. If it ends with a "C", the machine is not a printer. If it ends with an "N", the machine is a printer and you can move on to your next step of troubleshooting.
    • willy brown
      Thanks copier Guy. yes it is with the N all i have done even the access certificate from canon I put in that nunber
      • songela
        • Mar 2008
        • 216
        Check for permissions, i.e. make sure there are no restrictions in the additional functions menu,
        Regards
        • peterepeat
          • 84
          You may want to make sure you don't have a duplicate IP address. Unplug the ethernet cable from the copier and ping it again.
          Also check the firmware versions in Service Mode - make sure the print is listed. The license may not have entered or taken properly.
          • sjnordberg
            • Jan 2008
            • 14
            Check the driver
            I believe the 2880 comes standard with UFR II printing, make sure you installed this driver and not the PCL or PS unless you purchased those options.
