SYSTEM ERROR E007
  • Alphonse
    • Aug 2025
    [Error Code] SYSTEM ERROR E007
    MY COPIER REPORTS SYSTEM ERROR AND AS SUCH CAN NOT PRINT.
    I HAVE TURN OFF & OFF TO NO AVAIL, IT KEEPS TELLING ME SYS ERROR.
    SOME TIMES WHEN I TURN IT ON OFF OR LEAVE IT FOR THE NEXT DAY,
    IT MAY PRINT BUT AFTER THAT, IT REPORTS THE SAME MESSAGE.
    WHAT CAN i DO TECH?
    CANON C-IR2016
  • Brian8506
    • 1666
    Re: SYSTEM ERROR E007
    Fuser film torn. Replace upper fuser assembly or entire fuser
    • teckat
      • 16083
      WHAT CAN i DO TECH?
      CANON C-IR2016
      if u are a tech/ remove FUSER UNIT to inspect
      if damaged replace as noted by Brian8506
      don't forget to clear ERROR in service mode
      make sure green jam release lever is installed with the new unit.
      • MWALA
        • Sep 2011
        • 30
        Fuser Film error,
        If fuser film is intact, clean the white patch on the film usually it gets dirty and wont be read by the sensor
        • Alphonse
          hi tech done all that still to no avail
          still say system error
          and the display screen shows partly the message.
          so can copy the error code, it ends with 7.
          please help
          • Brian8506
            • 1666
            You replaced the fuser but still NG? If you can't see half the display, you need to replace it so you can see the whole error code
            • kuby
              • Oct 2007
              • 1410
              Replace the fuser, if the film is intact then the film is not rotating at the proper speed when machine is running.
