Here's the latest problem I've inherited:
Canon IR-6570:
This has been going on for 6 months or so. Jams when duplexing only. After about 50 pages or so it hangs up. Here's where the fun begins. IF left uncleared the machine will go into faults in this order:
1: E674-000C
Then, about 2 mins later followed by:
2:E732-001
3:E733-001
Errors can be reset and it will work again for 50 or so duplex pages.
IF you clear the jam quickly no errors are recorded. Only a jam code of 0213. However, it will jam at that exact same spot even with 1 page until you PO/PO the machine. Then it will be able to run 50 or so duplex again.
I have checked and cut and redone all wire wraps on the duplex and checked all sensors along the vertical transport for bare wires.
Anyone have any ideas?
Canon IR-6570:
1: E674-000C
2:E732-001
3:E733-001
