Hello I just got a second hand canon ir 3320i. But the hard isk is missig I'm in africa don't know where to get a new hard disk please help me to solve this problem. thanks in advance you can mail me at amson2001@hotmail.com
How to get and hard disk working
Re: How to get and hard disk working
Any one of these HDD's will fit your machine, eBay is a good cheap place to look, just search for the model number e.g ""MPC3032AT"
HDWN 'FUJITSU MPC3032AT
HDWN 'FUJITSU MPD3043AT
HDWN 'FUJITSU MPE3064AT
HDWN 'QUANTUM FIREBALL CX6.4A
HDWN 'QUANTUM FIREBALLlct10 05
HDWN 'QUANTUM FIREBALLlct08 04
HDWN 'QUANTUM FIREBALLlct15 07
HDWN 'FUJITSU MPF3102AT
HDWN 'TOSHIBA MK6014MAP
HDWN 'TOSHIBA MK6015MAP
HDWN 'IBM-DJSA-205
HDWN 'IBM-DARA-206000
HDWN 'FUJITSU MHK2060AT
HDWN 'ST34311A
HDWN 'ST34313A
HDWN 'ST310211A
HDWN 'FUJITSU MPG3102AT E
HDWN 'QUANTUM FIREBALLlct20 10
HDWN 'TOSHIBA MK1016GAP
HDWN 'IBM-DJSA-210
HDWN 'IC25N006ATDA04-0
HDWN 'FUJITSU MHN2300AT
HDWN 'TOSHIBA MK6017MAP
HDWN 'IC25N010ATDA04-0
HDWN 'Maxtor 2B020H1
HDWN 'MAXTOR 4K020H1
HDWN 'IC35L040AVER07-0
HDWN 'WDC WD300AB-00BVA0
HDWN 'IC35L020AVER07-0
HDWN 'SAMSUNG SV2001H
HDWN 'Maxtor 2F030J0
HDWN 'ExcelStor Technology J120
HDWN 'SAMSUNG SV0211H
HDWN 'IC25N010ATCS04-0
HDWN 'ST340015A
HDWN 'TOSHIBA MK2023GAS
HDWN 'IC25N020ATMR04-0
HDWN 'SAMSUNG SV0221N
HDWN 'FUJITSU MHT2020AT MF
HDWN 'ST92011A
HDWN 'SAMSUNG SV0411N
HDWN 'HDS722540VLAT20
HDWN 'ExcelStor Technology J640
HDWN 'Maxtor 2F040L0
HDWN 'SAMSUNG SP0411N
HDWN 'WDC WD400BB-22HEA0
HDWN 'WDC WD400BB-22JHC0
HDWN 'HDS728040PLAT20
HDWN 'ST340014A
HDWN 'TOSHIBA MK4032GAX
HDWN 'Hitachi HTS541640J9AT00
HDWN 'FUJITSU MHV2040AH
HDWN 'WDC WD800BB-22JHC0
HDWN 'ST940210A
HDWN 'ST940818AM -
Keep this in mind: Even if u get the above recommended hard disk from e bay or any of the computer stores there in Abidjan, don't think that you will simply plug it into the copier and expect it to work automatically. You will still need to do some work on it; you will need the service support tool (sst) to format the hard disk and load the the machine's system soft ware (firmware) in it, for it to work; and it takes a while to learn how to use these tools, let alone get them. The best advice in your case would be to contact the 'Canon agent or rep' nearest to you and allow their technician do the job for you. Alternatively get an experienced independent canon tech help you get the job done.
Good Luck.Comment
