IR3045
  • akm
    • Sep 2012
    • 155
    [Misc] IR3045
    Dear CopyTechTeam,
    i want your help to solve the problem with IR3045 that gives white copy when i make a copy or print the user data list
    thanks
    akm
  • teckat
    • 16083
    Re: IR3045
    Originally posted by akm
    Dear CopyTechTeam,
    thanks
    akm
    Copies and Test Prints are Blank. & There are no error codes.
    possible cause for this problem is the Laser Shutter not operating correctly. To check the Laser Shutter, first remove the Left Middle Panel.Open and close the right door while looking at the bottom of the laser where the shutter is located. You should see the shutter move from front to rear. If the shutter is not moving, check to see if it is out of place or that the shutter cable is working correctly. *Below is a view from the left side of the machine looking under the Laser Assy. The Left Middle Panel, Fax Kit, and frame cross-member have been removed.
    Make sure the Drum and Developer Unit are turning.
    If not, inspect if Main Motor Drive is slipping. replace if needed.
    Check to make sure the developing cylinder is turning.
    check the Developer Clutch (CL3)
    • Canuck
      Tech Specialist
      • 1713
      Re: IR3045
      Lets cut the machine in half....sky shot...crash it...anything on the drum? Yes...transfer. No...image formation(dev,laser,primary charging).... Also check the actuator on the right door. When closed it opens laser shutter. This model does not declare beam detect errors...just laser motor errors,so its possible that its a shutter problem like Teckat said. Check COPIER/DISPLAY/HV-STS...primary and dev bias to see whats going on
      • akm
        • Sep 2012
        • 155
        Re: IR3045
        tnanks Eng. Teckat for your very useful information and rapid help i will check the above parts and tell you
        • Canuck
          Tech Specialist
          • 1713
          Re: IR3045
          Is there an image on the drum...yes or no?
