Can I disable MI ImagePass from ImageRunner 105 to send jobs directly
  • jjjg
    • Jul 2012
    • 16
    • Can I disable MI ImagePass from ImageRunner 105 and directly print job?
      The M1 controller is giving me some memory problems. It's working but it takes 30 mins of toggling/rebooting to get it started. I want to disconnect it for fixing, but I need to print in the mean time.
      Can I hook up the IR105 directly to the CPU and print?
      If so what settings would need to be changed other than the actual cable hook up.
      I presume the Image Control number.
  • its_just_a_copier
    • May 2011
    • 132
    Re: Can I disable MI ImagePass from ImageRunner 105 to send jobs directly
    You would have to install a Printer Type Boot Rom to the Main Controller I think... This turns your copier into a printer.
