Hi!
I have one problem. I am the owner of Canon ImagePress Server Q2 which was delivered with ImagePress C1+ printer. The name of it is EFI Fiery PRO 80.
After having a thunderstorm strike into my house, the motherboard was fried and i had to replace it. I have become an identical motherborad s5197-efi.
So i have restored the disk with help of two DVDs which came with server. Those dvds recreate the installation of the WinXP (with sp2) with everything needed (drivers for EFI controlled,...)
The installation went fine but the problem is that Fiery.exe is causing the system to shutdown two minutes after startup. After the Fiery.exe starts and the process is on idle on the toolbar on top of the screen, the system automatically shuts down. If i kill the Fiery.exe with taskmanager the windows stays up until i start the Fiery.exe.
I am 100% sure that Fiery.exe is cousing this. Also all the hardware is ok and works. No errors in device manager and all drivers are fine.
Can you please help me what should i do?
Is Fiery.exe needed so that i will be able to print from other computer.
What can be the cause and do you have any suggestions? Maybe some kind of protection?
TNX for help in advance.
