Paper jam, open Left Cover
  • Andyboachie
    • 185
    Hello,
    Can anyone suggest further actions I should take. I am working on a Canon IR2016J. After I serviced the machine the above indication appears: "Paper Jam Open Left Cover". I have checked the sensors in Bypass and Fusing section. The cables connecting the door to the DC board are in perfect condition as well. Can anyone suggest something else I should check?
    Thank you
    Andy
  • northernlife
    • Sep 2011
    • 847
    Re: Paper jam, open Left Cover
    When you close the lower left door it depresses the same sensor that's used for the tray 2 pickup. If you open it there'll be a white long piece, You'll need to clean that especially the back piece. If you move it up and down you'll see the sensor flag pop up and down. Usually just a good cleaning, lubing should take care of this.2020_door_jam.jpg
    • Blizzoo
      • Aug 2013
      • 611
      You didn't say anything about the registration sensor,did you check it?try take off the plastic cover and inspect the tension spring if is working properly.
      • Brian8506
        • 1667
        You could also remove the lower cover on the back, assuming there's 2 trays, and disconnect the lower feed assembly and isolate it to either the top or bottom
        • Andyboachie
          • 185
          Hi guys,
          My issue got solved. There was a problem with delivery sensor. But I got it fixed, but the machine just starts running copies from tray 1 as soon as it finishes booting. Any suggestions?.
          Andyboachie
          • northernlife
            • Sep 2011
            • 847
            Sticky solenoid in the paper pickup assembly would cause that
