irac5045 E00012-0206
  • steve schofield
    • May 2010
    • 117
    hi have a imagerunner advanced 5045 with intermitted e000012-0206 has any one had this ...many thanks
  • northernlife
    • Sep 2011
    • 847
    Re: irac5045 E00012-0206
    Failure in rotation of magenta drum.
    1. Check connection of the connector with the Drum Motor
    M2)
    2. Check connection of the connector with Drum Driver PCB
    UN4).
    3. Check the ITB (to see if the ITB is displaced/damaged.
    Refer to E075 if the ITB is displaced).
    4. Replace the ITB Cleaning Blade.
    5. Replace the Drum Driver PCB (UN4)
    There is also modified sensors that give a little bit more play so they don't scrape across both sensors and cause issues. see attached pdfN08-051.pdf
    • steve schofield
      • May 2010
      • 117
      many thanks...will check encoders when on site
