Just for the Records:
I fought today with a IRADV8095 throwing me an E017-001 (ITB home position failure) and an E996-400 (Software Timeout failure [WTF?] ) in a row, but not steady (that would be far too easy), just every 300-400 sheets it throws first an E017, after a few minutes an E996
I upgrade the software to the latest and greatest, check for mechanical issues all to no avail. After a long time of try and error, i figured out, that this problem only occurs while using custom size paper (in this case 250x350 mm). As a temporary fix the customer prints on DIN A3I fought today with a IRADV8095 throwing me an E017-001 (ITB home position failure) and an E996-400 (Software Timeout failure [WTF?] ) in a row, but not steady (that would be far too easy), just every 300-400 sheets it throws first an E017, after a few minutes an E996
sheets, at least he will get his job done but with much more paper usage. I forwarded this problem to canon and we will see, what happens. This has nothing to do with the tech note "F1-T01-N11-10081"
Just a " Head Up" to you if you are running into similar problems
Stay tuned, I will keep you informed
Greetings from Germany
Herrmann
Herrmann
PS.: Sorry, but the Forum Software wrecked my whole Text formatting in ton
