iR1530. Scanner produces white copies
  • magc
    • 30
    A client of mine has a iR1530 to which I had to change the fixing unir because it had jamming problems.
    Now suddenly the scanner does not work. Copies are blank. But as a printer it prints perfectly.
    I replaced the contact image sensor (CIS), CIS flat cable and the analog processor PCB. The problem remains the same.
    Could someone help me where to go?
    Thank you very much.
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: iR1530. Scanner produces white copies
    Sounds like an interesting one. Don't suppose the fault follows the fuser? Did you re-install the old one to check?
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • magc
      • 30
      I've not it tried yet. But as a printer it prints.
      It seems the scanner doesn't read well. However, the CIS lights.
      • northernlife
        • Sep 2011
        • 847
        This happaned after you changed the fuser? What did you leave unplugged? the ribbon cables going to the CIS ok?
