Canon IR2200 Error message E000740-0003
  • abdulhussein
    Hello,
    At first I had an error E602, that mean hard disk damage. therefore, I replace the old hard with a new one.
    when i fix it and turn the canon IR2200 on I face a new error code E000740-0003
    what the problem? and solution?
    Thank you
  • kwazimoto
    • Jan 2007
    • 199
    your system software and your nic do not match.. up grade your system software...
    • kwazimoto
      • Jan 2007
      • 199
      one more thing I found was the memory on the main controller could be bad part num is wa7-3406-000
