IRC2880i White lines on black prints before & after replacing black drum
  • RayCR
    • Oct 2012
    • 18
    Hi all,
    Both before the black drum was replaced with a brand new drum and after PG10 prints as attached.
    There are white lines across the middle and bottom of the page but only on black... does anyone know how to cure this given I've already replaced the drum and the same thing is happening?!
    Thanks.PG10IRC2880i.pdf
  • vamoursly
    • Sep 2011
    • 273
    Re: IRC2880i White lines on black prints before & after replacing black drum
    Hello
    Is that a Canon original, or a rebuild?
    V
    • canonbundy
      • Jun 2012
      • 607
      Originally posted by RayCR
      Hi all,
      Thanks.[ATTACH]22306[/ATTACH]
      Did you use the Cleaning Wand (blue rod in front cover) to clean the Laser Glasses?
      BLANK LINES will only be caused from Toner scattering on the Laser Glass.
      BLACK LINES will be a a worn Drum/unit.
      You may find the original Drum Unit is ok - check the Life in SRV MODE > DISPLAY > MISC.
      • RayCR
        • Oct 2012
        • 18
        1. Replacement Black Drum is brand new genuine Canon not a rebuild or anything like that.
        2. Did you use the Cleaning Wand (blue rod in front cover) to clean the Laser Glasses?
        No did not do this... what is the correct procedure for this?
        • RayCR
          • Oct 2012
          • 18
          Before drum was replaced the life of the original was at 128 I believe.
          • canonbundy
            • Jun 2012
            • 607
            The info for the use of this Cleaner is printed inside the front cover, however above the Waste Toner Container are 4 rectangular "holes" or slots numbered 1 to 4 (4 being Black Unit) slide the Wand (with the Pad facing down) through the slots a couple of times to clean each Laser Glass .
            • RayCR
              • Oct 2012
              • 18
              Cleaning wand... all sorted!
              • RayCR
                • Oct 2012
                • 18
                Should I put the original drum back in?
                • northernlife
                  • Sep 2011
                  • 847
                  not with 128% life you'll be back there in a week or so. Save yourself the call and put the drum in.
                  • RayCR
                    • Oct 2012
                    • 18
                    Thanks for the advice all.
                    • northernlife
                      • Sep 2011
                      • 847
                      Make sure you do and show how to perform an auto grad. It fixes a lot of the wonky issues with colour reg being off and the like.
                      • vamoursly
                        • Sep 2011
                        • 273
                        The magic wand works wonders...
                        • Canuck
                          Tech Specialist
                          • 1713
                          Full Auto gradation(setting up gradation table..does Pascal,ARCDAT and d-half control...Quick does ARCDAT and d-half).....won't correct color mis registration. Perform color correction in user mode to fix color misregistration,or reboot(machine does color displacement correction on initial rotations,awake from sleep,or while printing). It will not do color displacement correction during full or quick gradation adjustment...i know this for a fact....just fyi
