irc3380
  • freefly
    • Jan 2013
    • 20
    irc3380
    Problem fix-e temperatures drop very low birth.
    is error e0003-001
  • vamoursly
    • Sep 2011
    • 273
    Re: irc3380
    E003 Fixing low temperature error
    0000 Condition
    In 20 sec after the fixing heater has gone on, the reading of the main thermistor
    is 120 deg C or less.
    Cause
    The main thermistor is faulty. The DC controller is faulty. The connector has
    poor contact, or the harness is faulty.
    - Replace the fixing sleeve unit (main thermistor).
    - Replace the DC controller PCB. *1
    0001 Condition
    In the course of printing temperature control, the reading of the sub thermistor
    is 80 deg C or less for 2 sec or more.
    Cause
    The sub thermistor is faulty. The DC controller PCB is faulty. The connector
    has poor contact, or the harness is faulty.
    - Replace the fixing sleeve unit (sub thermistor).
    • teckat
      • 16083
      Re: irc3380
      is error e0003-001
      Remove unit to inspect/ then Perform an error clear in service mode under Copier > Function > Clear > ERR
      If the fixing unit is not turning; fixing end thermistors, TH2 and TH3, will not heat up properly causing an E003 0001 to occur. This can be caused by the one way gear in the fixing drive assembly slipping, (ie: the fixing drive motor is turning but the fixing unit is not being driven).
      If fixing unit is being driven properly, follow the countermeasure recommendations in the Self Diagnosis section of the service manual for E003 0001.
      In many cases this error code was observed because the right door lower hinges break (crack). The right door will tilt slightly and not allow the actuator to activate SW3 properly, hence causing E003 error code.
      Clear the error code in service mode, and cheat SW3 and power cycle the printer to verify if the position of the right door is the cause for this error code. Upon successful verification, the replacement of either right door hinges would be necessary to resolve the error code.
      Item 50: FC7-7002-000 Upper Cap
      Item 47: FC7-7000-000 Upper Cap
      Item 48: FC7-7001-000 Lower Cap
      Item 70: FC7-7003-000 Lower Cap
      • teckat
        • 16083
        Re: irc3380
        SW3 is the Fixing unit's AC interlock switch. Sometimes the right door actuator will be bent and not fully press SW3 when the right door is closed. SW3 is a button switch located right above some of the Fixing unit's rear frame connections. SW3 has been found to show signs of wear and have carbon build up inside it. If the right door actuator is straight and making good contact , inspect SW3 and it's AC connections. If any flaws are found after inspecting SW3, replace it. SW3's part number is, FM2-9427-000. The image below is for reference purposes only, it points out SW3 and it's right door actuator.
        • vamoursly
          • Sep 2011
          • 273
          Re: irc3380
          Funnily enough I have 2 Canon IRC 2380i that have E003-002 errors
          Have ordered the lower caps, mine are broken....
          Will update
          V
          • Cabo
            • Aug 2012
            • 41
            Re: irc3380
            I have this problem, right door actuator was distorted because the lover cap was broken.
            • Canuck
              Tech Specialist
              • 1713
              Re: irc3380
              Yup, if the caps are broken,the door does not actuate the interlock(sw3 i believe) properly. Switch goes bad sometimes...usually not. Add a spacer between the arm and button actuator(?) in the switch assembly(see Teckats pic) if caps are ok and switch itself is ok. Of course you cleared the error in service mode.... I've installed a spacer on tons of these switch assemblies for E-003 codes
              • Simons
                • Jun 2008
                • 490
                Re: irc3380
                Yes, Only one I seen with this error had a door that was beat up. Put the fuser in another machine and it was cherry pie! bad door/caps
                • teckat
                  • 16083
                  Re: TOSHIBA STUDIO 452
                  Originally posted by copyprint
                  i HAVE A PROBLEM REGARDING THE SCANNER OF SAID MODEL TOSHIBA STUDIO 452,HOW TO OPEN AND ENABLE THE SCANNER TO BE USE.
                  U are in CANON forum /
                  is printer/scanner kit (GM-2060) connected ???????????
                  TOSHIBA STUDIO 452
                  e-STUDIO352/452 Customer Portal
                  Tutorial
                  This tutorial will help you learn how to perform various user functions at your e-STUDIO device, including:
                  * Toner and Paper
                  * Replacement
                  * Copy Functions
                  * Print Functions
                  * Scan Functions
                  * Faxing
                  * e-Filing
                  * Understanding Software
                  * TopAccess
                  * Troubleshooting
                  * Special Functions
                  see link--------Scanning Guide
                  see link---Handbook
                  ____http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&u act=8&ved=0CGAQFjAB&url=http%3A%2F%2Fbusiness.tosh iba.com%2Fdownloads%2FKB%2Ffile_uploads%2F8673%2Fe s450-452-453-sh-v25.pdf&ei=vkI0U5SQLJCh0gGA14GgBw&usg=AFQjCNHiZcud GHSvUR92TG-yYuzlrimgHw&bvm=bv.63808443,d.dmQ
