Error Code E000732-0001 IR 7095 Can someone help
  • ugaa
    • Mar 2013
    • 26
    I kept IR 7095 photo copier in store for a while since then when connected to the mains it shows this error code E000732-0001 woul any one help pls
    your help would be grateful.
  • Canuck
    Tech Specialist
    • 1713
    Re: Error Code E000732-0001 IR 7095 Can someone help
    Reader communication area. Reseat the cable from reader to print engine for a start
    • ugaa
      • Mar 2013
      • 26
      thank you for your help but some how can you explain more simpler because i don't have any clue where the reader is and the caple you explained. thank you again
