GOD "DUMB" IT ...!! I totally forgot about this...Thanks thought i was going crazy
today now i know what it is......Going back tomorrow.You da Man...
Originally posted by teckat
---------------------- Jam 0201
Paper Stops At The Registration Roller
In figure 102 item number twelve is a 28T drive pulley which has 'Bunny ears' that insert into the main drive assembly. The ears break off and the registration unit stops turning. The pulley was replaced , to resolve this issue
The part # for pulley is FU6-0040-000.
Jam Code 0201 shown on the Display. The paper will constantly stop at the Registration Roller. In parts check the Registration Clutch activates fine.
Copier>Function>Part-Chk
CL2 is the Registration Clutch
In a few cases the plastic sleeve that runs through the clutch that clips it to the shaft was broken.
Clutch part number is FK2-0361-000
