jam mark
  • andy19
    • Aug 2025
    jam mark
    my ir5570 indicated that there is a jammed paper, i have took all paper, but the machine still displaying paper jam mark, can anybody help me please?
  • mramlawi
    • Jul 2011
    • 838
    Re: jam mark
    Jam Code ? ???
    Distinguished road makes you jewel in rough
    • andy19
      Re: jam mark
      there is no code, and no red spot mark on display
      • canonbundy
        • Jun 2012
        • 607
        Re: jam mark
        Hi Andy, I'm guessing you're not a Tech, if you check in Service Mode - ADDITIONAL FUNCTIONS > press 2+8 together > ADDITIONAL FUNCTIONS > COPIER > DISPLAY > JAM (and) ERROR then POST the Codes/info displayed - someone will guide you from there.
        • Canuck
          Tech Specialist
          • 1713
          Re: jam mark
          Where does it say to remove paper from? What area? The inlet guide to the fuser has a power-on jam sensor..the arm sticks down from web oil vapours and paper fibers. Personally i cut the part of the arm that blocks photo-interrupt right off. Useless sensor..doesn't declare paper jams while running,just checks for paper at power on. Fixing inlet sensor..code is 0A17
          • andy19
            Re: jam mark
            thank you very much,
            i see in service mode-display-jam,
            the machine says to remove paper at outlet from fuser, i have remove the paper, there is no paper on unit 1 and unit 2, all jam was clear,
            then i reset unit 1 and unit 2, but the machine stil displaying jam mark, and no red spot mark, no jam code,
            the problem solved by restart the machine,
            • canonbundy
              • Jun 2012
              • 607
              Re: jam mark
              I'm not sure what you mean about 'RED SPOT MARK' .
              Post a photo of the JAM Display and also the ERR Display - Andy we need to know the Jam & Error Codes to enable the Techs to assist in solving the problem.
