Hi everyone.
This is not a technical issue - just a mere cosmetic problem that seems to be "normal."
The door on the second cassette tray isn't in alignment with the first cassette drawer. I can adjust the screw on the left side of the drawer and match it well but the right side is problematic. The white latching mechanism that expands when you push in the button is not long enough - or the metal catch on the rail that the latch fastens to is set to far back in the machine. I've taken a look at both areas to see if either can be adjusted and it can't. Is this common with canon copiers? Attached are two pictures so you can get an idea. Any suggestions are appreciated!
