Canon Imagepress C1 error code E000070-0101/0201
  • eusouopiu
    • Oct 2012
    • 27
    [Error Code] Canon Imagepress C1 error code E000070-0101/0201
  • teckat
    • 16083
    Re: Canon Imagepress C1 error code E000070-0101/0201
    E070 = Error in detecting ITB HP sensor-
    xx=01
    : ITB home position sensor B, xx=02: ITB home position sensor A; only at ITB 1/1 speed; XX=00: no distinction
    01xx = The period of time between when the home position of the ITB is detected and the next home position is detected is shorter than specified (-5% of standard duration). (884 msec or less)
    Turn off the main power, check the drive of ITB, and then, turn on the main power
    02xx = The period of time between when the home position of the ITB is detected and the next home position is detected is longer than specified (+5% of standard duration). (939 msec or more)
    Turn off the main power, and check to see if there is any scratch on the surface of the ITB; then, turn on the main power.
    --Check PS2 (ITB Home Position Sensor B) in I/O Mode, DCON Address P002 bit 9, to confirm the patch is being read.
    If the patch is not being read check the PS2 wire harness from the DC Controller (J1193A pin 15 to J3401A pin 2 on the Side Driver PCB and J3403 pin 2 on the Side Driver PCB to frame connector J251L pin 2). Clean sensor PS2 or replace it if the wire harness and connectors check good.
    If the patch is being read check the ITB Assembly and ITB drive for slippage.
    Check if the Primary Transfer Pressure Lever is engaged.
    The above picture shows the Primary Transfer Lever in the engaged position.
    • ommar
      • Aug 2013
      • 33
      hi all
      i want ask about where is (ITB Home Position Sensor B) and PS2 sensor
      thanks
