IR3235
  • copicatt
    • Nov 2008
    • 366
    IR3235
    Was under the impression these would scan to jump drive on the side of display? I have installed three that have universal send on them in more location. Does it need something else? Or am I not looking in the right area....I can't find it under the send tab.....help!
  • northernlife
    • Sep 2011
    • 847
    Re: IR3235
    To enable the machine to work with the USB memory stick perform the following steps:
    1. Go into Additional Functions > System Settings.
    2. Scroll down to screen 3 of 4 and press the USB settings button.
    3. Set "Use USB Device" to On.
    4. Set "Use USB Host" to On.
    5. Set "Use MEAP Driver for USB Input Device" to Off.
    6. Set "Use MEAP Driver for USB External Disk Device" to Off.
    7. Power the machine off and back on.
    Note: The above settings will not take effect until the machine is powered off and back on.
    Verify that the USB option has been setup correctly by looking at the Mail Box tab. It should now say USB under the words Mail Box.
    • copicatt
      • Nov 2008
      • 366
      Re: IR3235
      I checked/ changed the settings....cycled power. Still not showing under mailbox screen.
      under the machine configuration in counters screen:
      mem a capacity 256
      mem b capacity 512
      finisher s1
      copy tray j1
      dadf u1
      color universal send
      pcl
      ufrii
      super g3 fax
      • northernlife
        • Sep 2011
        • 847
        Re: IR3235
        If you plug a fat32 formatted usb device into the usb port does anything happen?
        • copicatt
          • Nov 2008
          • 366
          Re: IR3235
          The light flashes on the drive a couple times but no icon on display....
          • northernlife
            • Sep 2011
            • 847
            Re: IR3235
            hrm, lame. "USB Memory Connectivity Kit-A1" Sorry man.
            • copicatt
              • Nov 2008
              • 366
              Re: IR3235
              thanks, so I need to install that kit? How would I know if it's in there? Been trying to find a pic of it......also, when installed does it have to be licensed?
              • copicatt
                • Nov 2008
                • 366
                Re: IR3235
                Kit is installed. I can now browse. How do I print files at this step? Button doesn't go green either....
                • copicatt
                  • Nov 2008
                  • 366
                  Re: IR3235
                  Crud. Looks like i need to also install direct print kit f1... Read in another thread. They make it so complicated. I can scan to the jump drive but no print button.! Argh
                  • northernlife
                    • Sep 2011
                    • 847
                    Re: IR3235
                    You've gone through and done the steps that I had posted the 2nd post I believe it is?
                    You can print files of a maximum size of 2 GB. 1. Press [Mail Box].
                    2. Press [Memory Media].
                    3. Select the memory media → press [Open].
                    4. Select the document to print → press [Print].
                    5. To print a PDF, JPEG or TIFF file, select the paper size, press [Done].
                    6. Press [Start Print].
                    In order for this function to work, you will need the following items. Please pay attention to the notes for each item since requirements may be different for specific models.
                    Item Description Item Number See Notes
                    Additional Memory Type A 512MB 2726B001AA 1
                    Direct Print Kit- F1 1542B004AA
                    PCL Print Kit - AA1 2722B002AA 1
                    PS Print Kit- AA1 2729B002AA 1, 2, 3
                    USB Memory Connectivity Kit-A1 2729B001AA 4
                    Note 1: Standard on the 3245i/3235i models and optional on the 3245/3235/3230/3225 models.
                    Note 2: Requires the PCL Printer Kit-AA1.
                    Note 3: Requires the Additional Memory Type A (512MB RAM).
                    Note 4 : Requires the PS Printer Kit-AA1 or Direct Print Kit-F1 on the 3245/3235/3230/3225 models for the 'print from USB Memory Media' function.
                    • copicatt
                      • Nov 2008
                      • 366
                      Re: IR3235
                      Thanks. I've conclude I need the direct print kit. We'll see.
                      • northernlife
                        • Sep 2011
                        • 847
                        Re: IR3235
                        I really hate that Canon does that. If they didn't include the license they should come with the USB port capped off.
