IRADV-5030
  • garvin
    • Jun 2025
    IRADV-5030
    Hi have an irca 5030 that keeps rebooting.Any help would be welcomed
  • arias
    • Jun 2011
    • 11
    Re: IRADV-5030
    two happened the same problem having to change Main Controler 1 FM4-3833
    • kiwitech
      • Oct 2012
      • 29
      Re: IRADV-5030
      i have had a similar rebooting problem. reboot occured when start bar was about halfway across. the plug on the fax board was not fully inserted into machine. plug is left side rear close to plug from reader unit. should be able to check without removing any panels.
      • Canuck
        Tech Specialist
        • 1713
        Re: IRADV-5030
        Step 1...install newest firmware....
        • nghialuuvn
          • Jan 2008
          • 67
          Re: IRADV-5030
          Try to use Controller-self diagnosis function on iR Advance series.
          a/ Boot System Error Diagnosis Tool: Turn On machine while pressing Control Panel Power Supply Switch
          b/ Controller System Error Diagnosis Tool: Turn On machine while pressing simultaneously numeric key "2" and "4"
          If you could not go into that mode then I am sure that should replace Main Controller 1.
          Good luck to you
          • Nutstar
            • Mar 2011
            • 110
            Re: IRADV-5030
            could use some more information regarding your particular issue.
            there are many reasons for a system reboot to happen.
            at what point during the startup does the machine reboot?
            does it throw up an error message before restarting?
            have you tried to put the machine in download mode?
            • CanonSco
              Man About Town
              • Jul 2010
              • 368
              Re: IRADV-5030
              As above, Need.More.Info........Could be a lot of things. From corrupt print jobs to the Mn Cont.
              Yes, I am a nerd.
              Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
              • RHodg57
                • Dec 2013
                • 191
                Re: IRADV-5030
                We replaced a hard drive for an issue like this. Reloading software did not help.
