imagerunner c3200 error code
  • finestwine
    • 15
    i have a canon ir c3200 however i'm getting an error code E000020-01B0. can someone help me please.
  • lkrsardis
    • Dec 2007
    • 316
    ir3200n
    That code relates to the yellow drum unit. The unit was probably damaged taking it in an out. Replace it if you are a end user.
    Like the United States Postal Service It's a miracle it works!
    • Onetouch
      • May 2008
      • 62
      Yellow image unit,
      You have to change the "Yellow" image unit,
      Good luck,
      • Andronis
        • 5
        The fault occurs when an image is being
        formed. It is detected when toner supply
        operation is started.
        The ATR
        sensor has an open circuit.
        • kajsa39
          • May 2008
          • 28
          time to replace the yellow drum unit.
          Have you checked the value for that drum unit under S/M misc yellow if over 250 then change it.
