DOwnloading Firmware
  • Bobby Muhamad
    • Oct 2013
    • 5
    I have problem when downloading firmware IR5570
    when i try format hdd,
    i got notice "HDformat, if it is required, register it to the SST"
    and when i try to downloading firmware
    i got E244.
    what should i do??
    how to register HD format to the SST??
    regards
  • Iommanxman
    • Aug 2009
    • 180
    Re: DOwnloading Firmware
    Looks like your HDD is buggered. Do you have another one you can swap out and test?
    • northernlife
      • Sep 2011
      • 847
      Just to verify you're booting holding 2+8 and not going into service mode > copier > Function > System > Download right?
      • Bobby Muhamad
        • Oct 2013
        • 5
        I have tried with another HDD,
        and the result same
        • Bobby Muhamad
          • Oct 2013
          • 5
          i booting by holding 2+8 and going into download mode
          • Iommanxman
            • Aug 2009
            • 180
            Try a newer version of SST.
              • 16083
              where did u get these HDD's ---U can only use OEM HDD or the exact model pulled out--FK2-4907-000 (FY3-0314-000)-
              or WM2-5216-000
              SST E244 is a Write on the HDD
              EXAMPLE-----------
              C:\Canon File Folder\SST System Software Folder\SST Files\iR5570_v42.01\iRXXXX-XXxx0012-HDFormat.ift
              do u have the HDFormat.ift file registered in SST FOR THAT MODEL ????????
              • Bobby Muhamad
                • Oct 2013
                • 5
                or WM2-5216-000
                EXAMPLE-----------
                yes you're right
                i cant find HDFormat.ift file
                how can i get HDFormat.ift file???
                  • 16083
                  yes you're right
                  how u registered the 5570 firmware and it missed or it's missing in the 5570 folder under C:\Canon File Folder\SST System Software Folder\SST Files\iR5570_v42.01\iRXXXX - in the iRXXX folder u should see HDFormat folder.
                  if there do a re-register of firmware
